booting problem and psu
ronss
150
4
motherboard-ga-ma790-ds4h
psu-pc power and cooling 750
amd 970
the problem i have, is when i shut off the computer through windows, and then try to start the computer, nothing happens, the lights on computer comes on , no beep, no video, and i cannot shut off computer with power button.
solution-i have to pull the power plug on psu, hit the i/o switch, wait till the juice is out of the compenents, put the power plug back in, switch it to i, and then start the computer, and it will not start with a beep and video
i have tryed different psu,s, different cpu,s ,,,,,i am thinking the chip on motherboard is bad....
any suggestions????
ronss
150
4
i agree, sort of odd, one would think psu, but it has done it on 2 different ones....
ronss
150
4
whats odd, if i shut off the computer , and restart..then i have to pull the power plug on psu...but if i shut it off overnight and then start it, it will start without pulling power cord...wierd???
PreferLinux
420
Could still be the motherboard, but definitely makes the PSU suspect. What was the second one you tried?
ronss
150
4
going to try psu tonight,,,got to be that or motherboard.....i do too keep thinking psu
Meghan54
11,684
5,228
Almost sounds like a part inside the psu is heating up just hot enough to not shut it down because the fan's keeping just cool enough to run, but once you shut down, its temp spikes (no active cooling so it heats up) and takes a while to cool down enough to "cold boot".
Try another power supply that's known good.
ronss
150
4
bought a new motherboard, ASUS M5A88-V EVO, and everything is working perfectly...i did try another psu on the problem gigabyte board, and the problem was still there...i still think the chipset on the motherboard was not working correctly...just a quess
