Boot problem
bristow84
63
Ok so this has happened twice now and it's making me uneasy. For some reason, it does not find the drive with the boot file on it. Now this is odd because I only have a single HDD right now and it finds the drive fine. Now to get it to work I reset my PC once or twice and it finds the boot file and loads up. However it doesn't read the keyboard. I have no problem with that since I just unplug and plug it back in. But the boot issue is worrying me. Has anyone seen anything like this before?
Dec 10, 2005
28,052
12,666
HDD could be going out. Run HDTune on it.
And/or run the manufacturer's utility on it.
Also, be sure to backup all your data to another drive/source, just in case there is hard drive failure. It's a good habit to be in anyway.
bristow84
63
Well I sure hope that's not the case. I've only had this computer for a couple weeks.
EDIT: Windows Backup is good to use for backups right?
bristow84
63
ok. I have an external HDD so that will work.
I just ran HDTune on it and the only problem it says the HDD has is Ultra DMA CRC Error Count. Can anyone shed some light on that?
denis280
3,434
9
Cyclic redundancy check (CRC) is a method of verifying and correcting data after it is sent. What this warning is telling you is that at one point, data being sent/received by the drive failed this check. The most common cause for this is a faulty cable. or hdd starting to give up.
bristow84
63
Well if it gives, I still got warranty so yeah. And if it's a cable, I can get help for that. Still, damn
