For the string test, a gelatin capsule that contains a loosely-woven string is swallowed. One end of the string protrudes from the capsule and is taped to the patients outer cheek. Over several hours, the gelatin capsule dissolves in the stomach, and the string uncoils, with the last 12 inches or so passing into the duodenum. In the duodenum the string absorbs a small amount of duodenal fluid. The string then is untapped from the cheek and is removed. The collected duodenal fluid is expressed from the string and is examined under the microscope. Although more comfortable than some of the other tests, it is not clear how sensitive the string test is, for example, does it diagnose 60% (not very good) or 90% (very good) of cases of giardiasis.
Originally posted by: AbAbber2k
I'd bet money it's not real (haven't seen the clip myself). If you actually managed to do that, pulling on the string from either end would have the direct effect of pulling on your internal organs, cutting off circulation to said organs (some of which are quite vital) and in some cases severly damaging some of these organs.
Originally posted by: XabanakFanatik
I couldn't find it on Kontraband. It seemed so interesting!
Also, why/how could a virus make your LCD turn on and off?
no... don't think so.Originally posted by: The Godfather
Or he just cut string in half, put half in his mouth, stuck other half out his ass.
he didn't seem to be getting it to come out at the end. i guess we don't know how it actually came out.Originally posted by: AbAbber2k
