Not at all, I would LOVE one...but I am afraid of maintaining one with some mileage on it.
But your going to lease a car?! Work out the costs and your total budget.
For me it was £14k or a bit either side. You see a lot of very optimistic ads man...
Maintenance is okay from what I@ve read and it goes like this:
1k miles - Running in : free usually
11k - Oil £120-180 tops
23k Inspection 1 £400-500
34k - Oil £120-180 tops
45k Inspec II £550-780
Front Disc, front pads and rear pads £650 will need doing around 45-50k miles or so
Tyres £220 each but you can possibly find local independents that will do them for £160 each!
Get one thats had it's last major inspection done recently to avoid the Insp II, discs and pads and tyres. I don't need a service for another 12-13k miles with new dsics, pads and tyres
😀 I only need an oil service which is very reasonable.
Engines reliable just make sure it's had all the recall work done on it! For the UK you can get the VIN and the last 7 digits and get a BMW garage to check if it had all the work done on it. My car has and I'm happy with it.
Have a £2k warchest for any possible issues and your good to go.
The 135/335 idea is going to cost a fair amount imo! But go with what you can afford (I'd love a 430
😛) and makes you happy. Drive a beater for a few months to save up if you have to!
Koing
