Originally posted by: DanFungus
it looks like the one I got from a computer fair a couple months ago....
it has a switch on it so it can be put on always on, or on when "sound activated". I guess if you had it on a subwoofer then, it would do something, but it's basically "thump" activated
😉 If it is the same type as I have, it does
not have a to turn on or off. I had to make one myself
🙂 It does have a connector to connect to the power supply, but, I rewired it so that I could fit a switch in there, and then attached the switch to the front of one of the empty drive plates.
Here's some pictures of it
Link (I didn't put it
inside my case, because I don't have a window....yet
Disclaimer: All the above information is about the one I got, and this one that they have may not be the same as what I have.
Here's a pic of the technical specs that I have.
