Blue Screen of death issue please help
oakdad
4
I keep getting a BSOD after about an hour of play and it is the following.
Driver_IRQL_Not_less_or_equal
I have the following for a system
Tagan 480W PSU +3.3V@28A, +5V@48A, +12V@28A
MSI "K8N Neo2 Platinum" AMD Socket 939 CPU
AMD Socket 939 Athlon 64 FX-53
4 Sticks of Crucial Ballistix 512MB DDR PC3200 184-pin DIMM
Seagate 200GB 7200RPM Barracuda 7200.7 SATA Hard Drive
.3 amp Enermax Adjustable Speed 120mm Cooling fan
.14 amp Jamicon 120mm fan
.25 amp ZALMAN 80mm fan with Quiet Mode Adapter for CPU cooler
Thermaltake PIPE101 Model CL-P0006 for cpu cooler
Pioneer 108D 16X Dual Layer DVD+/-RW
MSI 6800GT graphic card
8 usb ports
2 1394 ports
On board audio
wireless mouse and keyboard
The Bios monitoring software is telling me my I have the following. ~3.12v, ~5v, and ~11.68v ~43c on cpu 24c for the case at idle and ~52c ~29c when I am playing my game.
jackschmittusa
5,972
It could be the vid card getting hot. Try operating it with the side cover off and a fan blowing on the card/mb. If the problem goes away, it is thermal related.
dclive
5,626
8 usb ports
2 1394 ports
On board audio
Check out my .sig's URL, and read thru the first post. Run MPS Reports, send me the .cab file, and send me the minidumps you've got.... *after* you've updated all your drivers & BIOS and *after* you've reproduced the problem (the crash) after doing the driver update.
