OneOfTheseDays
Does this cooler fit a GF4? I'm lookin for a replacement that is cheap and quiet since my existing fan is making noises.
Originally posted by: cockeyed
I'd also go with a copper Vantec Iceberq 4. If you do, be sure to measure the distance between the hold down pins. The Pro and non-Pro have different spacing but are basically the same. Cost ~ $15-$19.
I have the Icebery 4 Pro model on order for my Gainward Ti4200 GS which is spaced at 80MM between the pins. As I recall, the non-Pro model is 55MM between the hold down pins.
