Blowout FTL :(
Originally posted by: JEDIYoda
Originally posted by: Josh123
Originally posted by: spidey07
Originally posted by: tranceport
Nice. At least you are alive.
As long as he doesn't make any sudden movements he'll be fine (brake, throttle, steering wheel), especially since it looks like a rear.
Josh, were you towing anything? How as your tire pressure?
No, luckily I wasn't towing anything but the tire needed to be replaced.
no way!!! you replaced that perfectly good tire?????
I think he meant that the tire was due to be replaced.. Am I understanding correctly, OP?
They say 31.2 lbs but they had 35 lbs for the trip.
I doubt this.
You're right, I don't know what the hell I'm talking about and yes akshatp, the tire was needing to be replaced before the blowout.
My uncle had that happen with a 35x12.5 on his Ram. He took the truck back to Big O about a half dozen times before that telling them that there was something wrong with his tire. The tire piece seriously jacked up the side of his truck and the shop wanted to just replace two tires.
