- Sep 1, 2004
- 1,617
- 0
- 0
My trusty old epox 8rda+ died on me! I noticed some weird issues recently but I had no idea it was the capacitors causing them. Today my motherboard started beebing like crazy, so I unplugged it real fast. I made the mistake of rebooting it to try and enter the bios and go back to default settings (normally overclocked) and the cpu temp was over 80 celsius and rising before I unplugged again.
So I opened up the case and peeked around and then noticed that almost all of my caps were blown/leaking! The ones by the Vcore regulator were really bad.
So, assuming I didn't fry my cpu or anything else, I'm wandering if I can replace the mobo with a similar nforce board and still use my win XP installation? I know its possible to replace the caps but that sounds like a pita and it will cost nearly as much as a new board.
Im really worried that I won't be able to get the exact same overclock so windows will think I have a different cpu and mobo, which I assume will cause problems?
Anyone have any experience with this.
