Originally posted by: 5150Joker
Originally posted by: Ackmed
Originally posted by: Vesper8
well it's been confirmed today that the card is a 3 slot solution. and also that it's now official shipping
No, they are wrong. It can be a three slot solution, if you place the cooler just over the card. However, if you place it in any other empty slot, its a two slot solution. As you can put a card just above the video card, because the two slot stock cooler is no longer there.
Yep not a very difficult concept to grasp here guys, it's not rocket science. This card is very nice, if I didn't have water cooling I'd have gone for this.
Even if you move the cooler 4 slots down it's still taking up 3 slots in your system. The card clearly takes up 2 and the cooler takes up 1. 2+1 = 3.
Originally posted by: 996GT2
Looks like ATi is trying to squeeze the most out of their R580 setup instead of going to a more efficient architecture. I've read that R580 uses ~40% more power than G71 and G73.
Nontheless, it looks awesome
Apparently it is rocket science, because even if you move the coooler to another slot 2 slots for the card and 1 slot for the cooler still add up the 3. (2+1 = 3)
The card itself shouldn't take more than 1 slot, why they added the extra PCI slot holder to it is confusing. Like I mentioned above, most people don't use the 4x PCI-e slot that resides above the PCI-e 16x slot in most decent mainboards and that's where the cooler can be placed. So while technically it might take 3 slots, the 3rd slot it takes is useless for most.
Jeez you like to argue pointless stuff sometimes. Yes, if you have a dremel you can chop the two slot bracket on card in half and the card will be one slot due to it's thin profile from not having a HS on there and one more slot for the water cooler making two. Forgoeing that mod the card will render 3 of your slots unusable therefore it's a three slot card.
