- Oct 13, 1999
- 22,377
- 7
- 81
Biostar Tforce 6100 AM2 mini-review
I got mine from Newegg.
I spent a little bit of time using this board last night and would just like to give my quick thoughts on it. Besides the motherboard, I'll give some thoughts on DDR2 since I encountered some issues.
DETAILS:
micro ATX
Geforce 6100 chipset
1x PCI-E 16x
1x PCI-E 1x
2x PCI
4x DDR2
socket AM2
BIOS:
HTT 200-450MHz in 1MHz increments
VCORE +0.05/0.10/0.15v
RAM DDR2 400/533/667/800/1066
VDIMM 1.85/1.90/1.95/2.00v
GOOD:
mATX with overclocking (still not too common)
high HTT support
flexibility of IGP as well as PCI-E 16x
DDR2 support meaning you can now switch platforms w/o having to buy new RAM
support from the lowly Sempron to the top end dual core A64
Semprons can now have dual channel (not counting the OEM only socket 939 Semprons)
board has power/reset for easy bench testing
CPU fan header is the new four pin style, backwards compatible with traditional 3 pin
can now turn off Biostar splash screen on POST
passively cooled
BAD:
compared to socket 754/939 versions this board has really weak voltage options
can't find Memtest option in BIOS that other Tforce boards have
Northbridge heatsink really weak
doesn't have Smart Fan control that other Tforce boards have
new AM2 heatsink mount barely clears the heatsink - people who remove the IHS beware!
TEST PARTS:
AM2 Sempron 2800+
retail box HSF
2GB PQI DDR2-533 dual channel kit
Radeon X800GTO
Antec Phantom 350W PSU
random optical drive (testing done in WUBCD)
THOUGHTS:
Still decent overclocking for mATX, but doesn't live up to the excellent socket 754/939 versions of same board. Initially would just get RAM "beeeeeeeep" error from PC speaker with both sticks installed. One stick at a time was fine. Manually increased RAM voltage and decreased latencies (instead of leaving on "AUTO") and both sticks worked fine together in dual channel. This was while running totally stock speeds. I've read a lot of end-user reviews on various boards using DDR2 and many people have had issues with RAM compatibility - perhaps the workaround is to manually set stuff? Highest HTT was 275MHz tested in 5MHz increments. Will not POST at 280MHz, but was Prime95 stable (for the 30 minutes I let it run) at 275MHz with no vcore increase. The DDR2-533 RRAM was set to lowest DDR2-400 setting, but with HTT increased, my calculations put the RAM at 550MHz so seems as if RAM doesn't have much room for overclocking. Being that there isn't a lower setting for RAM, I'm thinking I should have gotten faster stuff. It's like trying for record overclocks on socket 939 using DDR266 - you hit the RAM limit pretty quickly. IMO the CPU at 2.2GHz isn't even breaking a sweat, but I won't know for sure until I get faster RAM. One neat thing though is that Biostar put all the accessories into a mesh zippered bag. It's not shown in the pictures, but is a nice touch. However, I'd rather have a better (as in more tweakable) BIOS than extra goodies.
CONCLUSION:
The board is fine if you need mATX since I don't know of any other AM2 mATX board that overclocks better at this time. It is also fine if you need IGP or want something cheap (around $75). You can have a $130 mobo/CPU combo that's pretty nice and upgradable, as well as overclockable. That's nice value. However, serious overclockers and people who don't need IGP or mATX are probably better off with an ATX board that has a better BIOS. Now for some general recommendations. With DDR2 there may be some issues with motherboards that may require manual timings for RAM to even work (chicken & egg problem). In time perhaps I will be proven right... or wrong. Also with DDR2, for anyone thinking of overclocking, even if you're a cheap bastard like me, buy faster stuff!!! I'm regretting getting the DDR2-533 and wish I had gone for at least DDR2-667 or 800. Anything faster than that is at a huge price premium, but I truely believe my overclocks are currently limited by the slower RAM since there's no RAM divider to drop memory down below DDR2-400 since that's the slowest "official" speed. With DDR, slowest was PC1600, which equals the 100MHz (DDR200) setting in BIOS, or PC2100 which equaled the 133MHz (DDR266) setting in BIOS. That gives the average person with budget DDR400 a fighting chance to hit 300MHz HTT by using the 133MHz RAM setting. There is no such luxury with "budget" DDR2 and for AM2 systems you'll need at least DDR2-667 to get near pushing the CPU to limits. For Biostar it is two steps forward and one step back. AMD took a sidestep for the most part, but the Semprons have gained value IMO.
DETAILS:
micro ATX
1x PCI-E 16x
1x PCI-E 1x
2x PCI
4x DDR2
socket AM2
BIOS:
GOOD:
high HTT support
passively cooled
BAD:
TEST PARTS:
AM2 Sempron 2800+
retail box HSF
Radeon X800GTO
THOUGHTS:
CONCLUSION:
