Biostar M7VIG - Non-Pro - Overclock help
Quiksilver273
7
Old Version of the motherboard, running it on an AMD 1800+.
Want to overclock but have heard the troubles with this board.
Nothing in the Bios. Wont let me change anything.
Any ideas?
Killrose
6,230
8
Never fear!! pinout guide is Here!
This will allow you to change multiplier/voltage, you might want to pick a setting that requires no cutting, but only painting across excisting jumpers to make it easier.
If you have a T-bred B/DLT3C, 2gig (2400+) at 1.55Volt is where I would set it.
