Binary for dummies help
OutHouse
36,410
616
ok i know how to convert binary to decimal, but HOW THE HELL DO YOU CONVERT DECIMAL TO BINARY.
say i want to convert 172.16.100.4 to binary the hard way of pen and paper what is the process.
her209
56,336
11
Here's a hint (numbers in base 10):
1057 = 1*1000 + 0*100 + 5*10 + 7*1
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
that could work....
for your example...
172-128 = 44 so 1
44-64 = -20 so 0
44-32 = 12 so 1
12-16 = -4 so 0
12-8 = 4 so 1
4-4 = 0 so 1
0-2 = -2 so 0
0-1 = -1 so 0
10101100
easy peasy
OutHouse
36,410
616
Originally posted by: TheStu
that could work....
for your example...
172-128 = 44 so 1
44-64 = -20 so 0
44-32 = 12 so 1
12-16 = -4 so 0
12-8 = 4 so 1
4-4 = 0 so 1
0-2 = -2 so 0
0-1 = -1 so 0
10101100
easy peasy
you just confused the crap out of me.
TheStu
Moderator
Sep 15, 2004
12,089
45
ok see... you pick one of the numbers just slightly smaller than the number you have chosen... if it is IP addresses they cant get any bigger than 128 so you start there. So you take your number and subtract 128 if you get a number that is zero or larger, then it is a 1. If you get a negative, it is 0, and move on.
OutHouse
36,410
616
here is what i am doing that is wrong.
172-128=44
44-32=12
12-8=4
4-4=0
I know the answer is 10101100 but dont know how to get it.
dighn
22,820
4
you need a table of powers of two eg.
exponent number
7 - 128
6 - 64
5 - 32
4 - 16
3 - 8
2 - 4
1 - 2
0 - 1
if you can subtract 128, put a 1 in the 7th place (which is really 8th place if you use 1-based indexing)
for your example, since you can subtract 128, 32, 8 and 4, you put 1's in the 7th, 5th, 3rd and 2nd place. this is of course 0-based indexing, so there's a 0th place as well
eg:
place 76543210
numb 10101100
OutHouse
36,410
616
that could work....
for your example...
172-128 = 44 so 1
44-64 = -20 so 0
44-32 = 12 so 1
12-16 = -4 so 0
12-8 = 4 so 1
4-4 = 0 so 1
0-2 = -2 so 0
0-1 = -1 so 0
10101100
easy peasy
It just clicked. Thanks!!
her209
56,336
11
that could work....
for your example...
172-128 = 44 so 1
44-64 = -20 so 0
44-32 = 12 so 1
12-16 = -4 so 0
12-8 = 4 so 1
4-4 = 0 so 1
0-2 = -2 so 0
0-1 = -1 so 0
10101100
easy peasy
Bahahaha!
neutralizer
11,552
Obligatory: There are 10 kinds of people in this world, ones that understand binary and ones that don't.
MajinWade
334
If you just wan to do it, here is another method.
172/2 = 86 rem 0
86/2 = 43 rem 0
43/2 = 21 rem 1
21/2 = 10 rem 1
10/2 = 5 rem 0
5/2 = 2 rem 1
2/2 = 1 rem 0
1/2 = 0 rem 1
so going up: 10101100
Fractions:
.161
.161 x2 = 0.322 so 0
.322 x2 = 0.644 so 0
.644 x2 = 1.288 so 1
.288 x2 = 0.576 so 0
.576 x2 = 1.152 so 1
.00101 with simple truncation.
so 172.161 is 10101100.00101
ok, now do -172.161 ;)
