"Biking" equivalent for upper body?
Status
Not open for further replies.
Syringer
19,333
After biking for a while now I've noticed a quite a size increase through most of my lower body, much moreso then when I was doing squats/dead lifts and the like--and whenever I see a hardcore biker out there their legs are generally just massive.
Is there some sort of equivalent exercise for one's upper body, and would it be as effective at increasing size as biking is for the lower body? Common knowledge generally teaches us that for size, lower reps with heavier weights is the way to go--but why does biking provide such size increases?
zebano
4,042
Rowing? Just a guess since I don't really care about upper body size so much as losing weight so I don't end up with knee / general health problems.
StageLeft
70,150
Hand cycling probably would do a good job of it, so yes that would be it. I think rowing helps, too.
Their legs are big not from the activity so much as the activity plus long hours of doing it. The quickest way to size is still heavy weights. I have noticed great gains in leg size from cycling over the years, but the hours spent, if size was my prime concern, could have been more rewarding with weights, I'm sure.
mchammer187
9,114
Are you confusing size with leanness and definition?
Even someone like Lance Armstrong does not have huge legs imo. Are they super cut and more defined yes. But if you are going by circumference ( a direct size measurement) I'd say they are not insanely large or anything.
Status
