big wireless problems please help
oldman420
i get continuasly kicked from my router and lose connection this happens randomly and sometimes my pci card cant even see the router. am i being hacked or have i got bad epuip, lack of knowlege? i attempted to create a secure net and thaught i had
i turned off broadcasting turned wep onand still im having this problem
i hardwired my connect to be able to make this post
i am using a linksys wireless b setup
thank you for any help
jerome
What model Linksys switch are you using? Also, when you disable WEP and turn on broadcasting, do you have problems staying online? If it's stable then, try to turn on WEP first (make sure that you use the same key length on each machine), and then if that's stable, try to turn off the SSID broadcast.
Also, what's your signal strength on the wireless connection (you should be able to check that by using the wireless utility that you configure your machine's connection on)? I found that if my connection was weak, it would randomly drop if anything nearby generated any noise.
