- Aug 22, 2006
- 362
- 0
- 0
I just installed a Big Typhoon onto my P5W DH Deluxe and it did indeed lower my temps considerably but now I've got a weird (dangerous?) issue going on. While monitoring the two independant cpu temps, they're fine... 38 idling now compared to 44 before... but when I start to run orthos, the diode temp (the default cpu that asus reads) begins to really, really climb. From 28 degrees C to 70 C! Something has got to be wrong here, any ideas? I put the foam thing and insulator on the back of the motherboard as indicated in the directions, could this be causing my problem? Thanks for the help, asap!
