Cloudfire777
You clearly haven`t paid attention the the latest leaks.I wouldn't be surprised in the slightest to see a 20nm GM204 this fall.
Try googling for GM204 under pictures. Examine that die.
There is no way that is 20nm
I saw the pictures. What, specifically, leads you to believe it isn't 20nm?
That GK104 in 28nm is 295mm2 while GM204 is 430mm2.
Not a good way to start off with 20nm to put it lightly...
#1Wait...so now a bigger die is bad? I thought people were wanting "Big Maxwell" right out of the gate.
Seriously, you're willing to proclaim feature size based on the chip size? Really?
#1
GF104 40nm- 332mm2
GK104 28nm - 295mm2
GM204 ?nm - 430mm2
#2
A 430mm2 20nm GM204 would feature a massive amount of CUDA cores and its not needed because Maxwell cores perform better than Kepler cores. Do you really think Nvidia would release a GPU capable of doubling performance over GTX 780Ti? No they do it step by step, hence why you see all the first high end GPUs sticking to around 300mm2 dies when a new node arrives.
That they increased the die from 295mm2 to 430mm2 is a huge tell that they did it to be able to fit more transistors on the chip because they are still stuck on 28nm
Read my post again.That logic doesn't even explain 28nm though.
50% increase in die area and a ton of more transistors overall compared to GK104 and even GK110. It would be too fast. Period.If they didn't reduce size, that's still a ton of cores added in that extra 135mm^2 (nearly 50% increase).
You go down a node, you double the transistors. You go back a node, you get 1/2 the transistors on the same area.How is it that your logic doesn't mean that they went back to 40nm?
I just gave you a reason why they would.You're also completely going off of the assumption that they will always try to launch the first one at 300mm^2.
What if they didn't? All your assumptions go out the window, at that point.
http://www.kitguru.net/components/g...0nm-process-technology-jump-straight-to-16nm/
Nvidia may skip 20nm altogether
