Big gaps between cars at the stoplight
uclaLabrat
5,632
3,045
Drives me crazy when people do this...10 feet ain't going to save you much if you do get rear-ended. However, in an intersection, real estate is at a prime. Leaving all kinds of space makes cars hang out all over the place, into other lanes, blocking traffic, etc. I see it all the time, cards with like 3 lengths in front of them, and the tail end of the line is blocking my turn at moving on my green...then again, this is LA and everyone needs to be shot
lupi
32,539
260
It is illegal to block an intersection. If people are doing that, it really doesn't matter how much space people are leaving in front of them.
bunnyfubbles
12,248
People sitting there cruising in the passing lane on highways (especially when they're going slow) pisses me off more than people leaving large gaps.
rh71
52,844
1,049
I've always just left enough room so I could get into the next lane should they stall. I never really thought about leaving room in case I get rear-ended... so I don't hit the guy in front of me. I'd be going pretty far forward anyway, no? 10ft is a bit much.
hanoverphist
9,867
23
Originally posted by: RKS
certain stop-lights (especially left-turn arrows) are activated when cars park over sensors in the road. sometimes these sensors are imbedded a few feet back from the light so they are activated only when traffic builds up. maybe these drivrs know where these sensors are. i know aroud here these are usually easy to see.
i only do that in turn lanes, since that third car is what triggers the green arrow. and only if theres only one car in front of me. otherwise, i get up so i can see the tires over my hood. if people look back and creep up, ill creep and get even closer. for some dark reason i love it when people freak out about that, so i push them on it. someday i may get into an altercation over it, but hasnt happened yet. i have had people yell out their window at me about it, jump up and down on their seat and all kinds of stuff tho. pretty funny.
what pisses me off to no end is the people that leave those gaps both at the stop and while driving down the street in heavy rush hour traffic. tighten up, youre leaving space dammit! that space is where every jackass in a car will speed up and merge in front of you, making the people behind you wait even longer to get home. stop slowing people down and get in gear!
Born2bwire
9,840
That would be understandable. The ones I usually see, though, aren't at the head of the pack.
I've often seen sensors in groups of threes or so. The first two sensors are back to back at the stop line and will detect the first two cars. The third sensor is a few cars back to see if they are really piling up. I hated driving in Portland because a lot of the traffic lights only react to the sensors as opposed to a combination of timing and sensors. It was near impossible to pass more than two intersections without having to stop to activate the light.
DangerAardvark
7,559
I hate it when half-asleep douchebags wait a metric eternity to step on the gas after the light turns green.
Ricochet
6,390
19
Originally posted by: MrDudeMan
Originally posted by: ViviTheMage
I hate when cars just creep, creep, and creep more.....annoys the hell outta me when they do that for some reason.
QFMFT
Wears my clutch for no reason. :|
QFGDT!!!!!!!!!!
I lovers my clutch
:roll: You don't have to move as slow as they do. Sit still until they come to a stop, and then move forward. It's not rocket science. Yes, I drive a stick as well.
I don't even drive a stick and this annoys the fvck out of me. The problem is they'll creep..then stop..so you close the gap (not wanting to be the douche that leaves too much room)..then they creep some more..and stop. One guy did this 5 times at one sitting. WTFBBQ!! FIVE TIMES!! What in holey gawd reason would anyone do this?!! It is simple enough to leave the desired space in front of you in one fell swoop. Somewhere behind me some poor schmuck is trying to get past the divider to the left turn lane.
zoiks
11,787
QFMFT
QFT!
I was about to get road rage sitting in my cube right now.
clickynext
2,583
I usually leave a good distance, at the very least half a car length. First, obviously to avoid a chain collision because those do happen fairly often. Second, to give myself the ability to safely pull out into the next lane if for any reason I need to, like the car in front of me breaks down, which also happens on occasion. Third, even if there's not half a car length there, the person in front will creep ahead until there is, and I don't like moving again unless there ends up being a really huge gap.
BabaBooey
10,476
I always leave at least 2 car lengths as no crackhead is going to carjack me and then you have the idiots out there yakking on the phone and drinking their starbucks ,gotta avoid them morons from rear ending me and yes it has saved me from 2 rearenders in the past..
Maybe you need to relax and if thats the only thing that bugs you so that you make a thread about it then congrats to you....I envy you...:beer:
PingSpike
21,756
600
Heh. There's a couple lights where I stop at the light, let my foot off the brake to roll the car back and then drive up again to trip the sensor. They take two triggers for some reason to get an instance switch.
PingSpike
21,756
600
This is what makes me wish that if I concentrated hard enough I could make people's heads explode. The best part is...they always wake up at the last second and then jet under the light...leaving you fucked and them with no punishment at all.
PingSpike
21,756
600
I always get up pretty close because when there's traffic, I remember what its like being that guy thats 10ft from the start of the left turn lane I want to get into...but can't because the cars won't move up.
Whisper
5,394
I'll leave perhaps 5 feet between my car and the car in front of me so as to be able to turn out of the lane if needed. 2-3 car lengths is excessive IMO, though; if everyone did that, the line ups at stoplights would be insane, and--at least as is the case at many signals in both Atlanta and Baton Rouge--only three or four cars would get through rather than half a dozen. During rush hour, that makes a HUGE difference, especially when wait times at said signals are in the 2-3 minute range.
silverpig
27,703
12
Originally posted by: GenHoth
It isn't like they're slowing you down, so is it really important? At a stop light I honestly couldn't care as long as they get out of the gate in good order. (sometimes I leave quite a bit of space and then take off, just to have some fun!)
It doesn't really bother me. It's just something that I'm curious about. The only time I would be peeved by it would be if they were keeping me from entering the left turn lane while having a 2-3 car gap in front of them.
Yeah I hate this. When I'm in the blocking position I always try to stay as far to the right and forward in my lane as I can to let the traffic wanting to get into the left land pass.
dugweb
3,935
QFMFT
QFGDT!!!!!!!!!!
I lovers my clutch
why do you have to creep forward if they are?
i just stop my car where i stop it, if the person in front of me creeps forward, then there will be a larger gap in between us. Something that also apparently annoys the OP.
this thread is stupid
he was probably doing it on purpose just to see if you would keep creeping
shocksyde
5,539
I will sit a few car lengths back when I know I need to get over. I then accelerate rapidly and sneak in as the cars in the next lane start to move.
If something like this is bothering you enough to post on a forum, then you've got some issues.
Daishiki
1,943
36
I don't see where in my OP that I claimed to be un-relaxed, bugged, or bothered except for the particular case I mentioned in a reply post. I'm just merely curious to see if there was some trend going on that I didn't know about. If I were here to rant and whine, I'd toss in some exclamation marks for good measure and you can bring the cheese.
theknight571
2,896
Depending on where the intersection is I try to leave enough room for me to turn out of the lane if needed.
There are parts of the city where at night I don't even stop at the red lights... fortunately I don't have to travel to those areas much anymore.
Oceandevi
3,085
You have to mash the brake with an auto. It gets boring and you start to bounce it and creep up. And your ankle gets sore.
thomsbrain
18,148
I'm sometimes tempted to pull out and "parallel park" in front of them so they get the picture. the problem with it is that it can force traffic to back farther out, occasionally blocking driveways or intersections. if i'm following someone and i see there is room for two cars on the other side of the intersection, obviously, i'm crossing the intersection after the guy in front of me. when that jackass stops 15 feet short of the car in front of him, i'm stuck in traffic. also, when the person stops so far short, they catch everyone behind them off their guard, and make everyone else brake harder because they suddenly have to stop 20 feet sooner than anticipated.
alkemyst
83,769
19
Yeah I hate those asshats too...usually the short stop like 30 feet early, then just slowly stop/roll/stop/roll
With a manual it's a freaking PITA. They do it at stop signs too and then never really come to a complete stop at all causing pandemonium at a 4 way.
