spacejamz
bought a compaq 2100 BTO last year...always had the factory installed os on it...battery life was about 30 minutes on stock battery and less than an hour on the valance external power...
last weekend, I just did a fresh install of XP PRO only and then reloaded all the drivers etc...
now the stock battery lasts nearly 2 hours and the valance power supply lasts over three...is there something in the factory installed os that would drain the battery like that?
prior to the os install, the CPU usage was pretty light (under 3% usually)...power setting is always set to laptop...and I always have max brighntess on the display...just wondering....
