BFG 8800 GT OC Revisions
sutahz
1,300
I thought you were going after stability... As for performance, you won't be able to tell the difference between CL3 and CL5, 1T or 2T or any of that. Memory is not as important as it once was.
Keysplayr
21,219
55
Originally posted by: taltamir
try memtest.org ... I don't know of ANY (EVER made) DDR800 5-5-5-15 ram that is rated to run at 1.8 volts (despite 1.8 being the standard for DDR2). Now some CAN... but its not RATED for it.. its either rated for 5-5-5-18 on 1.8volts. Or its rate for 5-5-5-12 (or 15) or 4-4-4-12 (or 15) for 2.0 or 2.1 volts. (a rare few are rated for 1.9 or 2.2 even)
Check your ram's EXACT model number online to see the true rating. Either slow it down to 5-5-5-18 or up the voltage to the required level.
If you cant, consider new ram.
Not sure if this is what you meant.
DDR2800 5-5-5-15 1.8-2.0v
