BFG 6800GT OC $349 @ Outpost.Com
Andrax
64
Updated topic... I would keep checking, when they get more in stock, I bet the link will work once again.
Andrax
64
BTW, mine should be here tomorrow and I will update the thread with wether or not its the reference hsf design or if its the new dual fan design as displayed on the BFG website.
Tenaku
11
I was in fry's the other day, and the card they had there (which has the same SKU as the one from outpost.com) uses the dual-fan heatsink... mine will also be in tomorrow, and I'll update as well.
CrazyGamer
356
I've heard the reference cooler actually works better by 5C~8C difference. The dual fan cooler is more for looks, as both fans are blue led. I have the dual cooler on my FX5900 and it does really well, but I can't say other than what I've heard for the 6800 series.
imported_jlm46
18
Hi,
Just wanted to post for those asking which design it was - I received two today (even though I had ordered when it said out of stock) and they're both the dual fan / blue PCB design.
Thanks very much OP! Been looking for a reasonable deal on these ever since missing the bestbuy price mistake!
Tenaku
11
Originally posted by: prometheusxls
If these come back in stock can you match BB B&M to outpost?
nope. BB doesn't match internet retailers, and fry's considers outpost to be seperate...
Andrax
64
Yeah, got mine today. Custom cooler :( I was hoping for the reference design, but ohh well. Now I can finally put that ASUS K8V Deluxe + AMD 64 3200+ system together.
Glad to hear a good amount of people got in on the deal!
foofoo
1,344
mine came in today and was also the dual cooler.
but this thing is way faster than my 9800xt!!!
INGlewood78
939
Glad some people got the deal. I have the BFG custom cooler. It looks like it should perform..but it sucks :(
Scopolamine
58
sorry to hear about the custom coolers. But at least you got a great deal and you can use the money you saved to buy a NV silencer :)
CU
2,417
51
It takes up 1 slot and mine from BB overclocks to 390/768 with the BFG custom cooler. It idles at around 50C and under load is around 60C. So I don't think it runs that hot. I do wish the memory would do better, but this is what coolbits and rivatuner tell me the max are. Does heat effect the ram overclocking much?
Edited:
Oops, I was thinking you where talking about the nu sorry about that.
QuicknDirty
306
Wow, that's all it OC's to? I got mine from the original BB price mistake, and I've gotten it to OC stable at over the 6800 Ultra OC speeds of 425/1100 with just the original reference HS/Fan.
I'd suggest playing around with it, I think you should have much more headroom than that.
QnD
eVaoVe
225
Is the BFG Custom Cooler that bad? Should I just buy an eVGA that uses the reference cooler?
CrazyGamer
356
From what I've heard the reference cooler seems to cool 5-10C better than the BFG custom cooler, not a major difference, but on the positive side I believe it is quieter than the reference cooler.
