Slomo4shO
- Nov 17, 2008
- 586
- 0
- 71
3 monitor surround doesn't require the active display port adapter.
Neither does the 290 or 290X... Also,the Hawaii GPUs have hardware based frame pacing...
No they don't.
Frame pacing for multi-GPU systems, at any resolution (e.g. Eyefinity/4K), is fully resolved in hardware on the 290 and 290X
so the XDMA engine is not strictly speaking a standalone device, nor is it a hardware frame pacing device
Or so they say?
http://www.anandtech.com/show/7457/the-radeon-r9-290x-review/4
What piece of hardware are you referencing if not XDMA?
Or so they say?
So I am unsure how your stance refutes my initial statement that Hawaii has hardware based frame pacing solution... there was no claim made that the hardware can function without driver support.XDMA is the final solution to AMD’s frame pacing woes...
the purpose of this hardware is to allow CPU-free DMA based frame transfers between the GPUs, thereby allowing AMD to transfer frames over the PCIe bus without the ugliness and performance costs of doing so on pre-GCN 1.1 cards.
My statement was within the context of this discussion for multi-monitor frame pacing. The 290 and 290X has a hardware solution that utilizes the existing algorithms for single GPU frame pacing and expands it to crossfire and multi-display scenarios. Since XMDA is only available on the Hawaii chips, there is still a need for a multi-gpu algorithm for the older generation cards. The 290 and 290X has had multi-monitor crossfire frame pacing through a conjunction of existing driver algorithms and XMDA. Even the article that Balla quoted acknowledges this:The key idea is that you can't just add a piece of silicon and magically have frame pacing work great.
Meanwhile this setup also allows AMD to implement their existing Crossfire frame pacing algorithms on the new hardware rather than starting from scratch, and of course to continue iterating on those algorithms as time goes on.
Do you even bother to read what you quote?
I thought the XDMA CF route minimizes frame variation since its going directly to each other, bypassing the CPU altogether. This would infer there is already minimal variation and/or latency already so any software solution is just icing on the cake. Reviewers notice dramatic smoothness compared to older CF cards (which only have software frame pacing).
ps. A lot of people always worry about PSU issues, but a HQ one will run at its peak 24/7 without a problem. 850W Seasonic is plenty. Stock, 250 + 250.
