hardcore_gamer29
hi friends i want to know the video settings for bf4.i have asus gtx770oc and i5 2500k @stock.i want to stay at 60 fps constant so please guide and thank you
I have a 4670k (not overclocked) and an MSI GTX 770 OC, and it stays right around 60fps with everything set on ultra, MSAA on highest setting, HBAO enabled, at 1080p. Would his 2500k really be that much of a bottleneck to keep him from getting similar results to me with everything set on ultra?
turn off MSAA, turn off HBAO/SSAO, You can leave textures and filtering on high. Set mesh quality to Ultra (it gives more visibility), and turn all other settings to low.
In the 12 hours this thread has been alive, I have to believe that just messing settings on your own would have been much faster.
i have asus b75 chipset so cant oc 🙂 by the thanks
Are you playing 64p mp? If so I'm not seeing your minimums at 60. Then again if the "only" concern is BF4 then we should have went for a GCN card and mantle support.
that low settings on gtx770 serious?
