We will take this one small step at a time.
The (NAD)2400...Power Envelope circuitry produces 370-440 watts per channel of tone-burst power for music.
NAD stopped using its well-known peak output power promoting technologies like Power Envelope and Extended Dynamic Power.Originally posted by: tronester1
Im still not quite sure I understand what you are saying. As for the "power envelope" technology, I have NEVER heard of that?
When an amp is used to drive low impedance loads (1-2 ohms) you may stress it beyond its design capacity. The lower the impedance the more amps a circuit is required to deliver causing the transistors to overheat (Ohm's Law) and it is more expensive to design an amp to handle low impedances. Remember Apogee electrostatic speakers? They had a very low impedance and had an annoying habit of eating amps, only a few high end amps could handle the load.The impedance of the speaker does not correlate directly to the efficiency. If that were the case, why would we not be using 1ohm loudspeakers instead of 8ohms?
Actually an amp that is over driven and distorting will destroy a speaker a lot quicker than a clean amp. In other words, a 25 watt amp driven into distortion will destroy a speaker while a clean 100 watt amp will drive the speaker to a louder dBA without harming it. And as for straight DC, a battery is an excellent way to test the polarity of a multiple speaker setup, just don't use a car battery.The distortion levels have no correlation to how much power the speaker can handle. A speaker sees power as power, it does not matter if it is distorted or not. You could even feed a speaker a straight DC current. The distortion does not destroy the speaker, it is the increased power level that comes with it that does.
