Better Overclocking 512mb ddr ram ?? Mushkin , Crucial or Corsair ?
kulki
739
can someone plz help me out here. I am building a system for the heck of it. But I only use my puter for surfing the internet period.
Now I cant decide between generic 2100 and Micron 2100
The difference between them is 57 as opposed to 68. Is there going to be a significant difference in the quality between these two memories and their performance. Also I am hoping to OC to like 140fsb will any of these memories give a problem on a 1:1 ratio setting?
CamisaAmarela
48
Could anyone tell where I can find some material explaining about memory. I want to know what is the difference between a
PC2100 and PC2700 or between 5ns and 6ns, etc. I'm complete ignorant about this matter.
Tks.:)
Possum
536
How can you tell when the limit you hit from overclocking is due to the CPU or RAM? I have a 1.6A overclocked completely stable with a 155 MHz bus and 1:1 bus to memory ratio on an ASUS P4B266. At 155, I can set the BIOS RAM settings to the fastest (2-2-2-6 or whatever, Turbo 2) and be fine. At 156, I can't boot with Turbo 2, but can with "Normal." From 156 to 160 MHz bus, the computer will boot and be ok in Windows XP for 10+ minutes, then XP will blue screen, write RAM to the hard drive, and reboot. Is this indicative of the CPU causing errors?
BTW, my RAM is a 512 MB DDR stick from Crucial, but I forgot to check what chips it has.
EDIT: I just checked the chips - they're Samsung.
RalfHutter
3,202
Possum - at 155 1:1 you're at 310Mhz on your 266Mhz Crucial RAM. I've got the same RAM (but with Infineon chips, not Samsung) and the most I can get out of it on my P4B266 is around 305Mhz before I get problems. That's probably all you're going to get out of it.
I just went to Konmax (they're about 5 minutes from where I live) and bought 2 x 256 sticks of Kingmax PC2700 RAm. The chips say "-05" on them. I hope this is 5ns.
I also called Kingmax tech support and they said ALL their DDR333 RAM is 5ns. They claim they don't make anything else.
manko
1,846
<< I also called Kingmax tech support and they said ALL their DDR333 RAM is 5ns. They claim they don't make anything else. >>
(sorry for double posting, but...) Check out this Tweak Town review of Kingmax DDR333: they say it's 4ns in the chart, but on the close up pic at the very bottom of the page, you can clearly see "-06" on the chips:
Kingmax DDR333 review
LoverBoyJ
992
same here, I just want a single stick of 512mB DDR333 (kingmax 5ns ram would be really good) and add another 512mB when the price drops. Most mother board have a note that only 2 slots can be used if running DDR2700. I believe this can also be found on the SIS645 chipset review.
