Besting Gaming(Air cooling) Case for the money
The extension could work, you leave the extension plugged into the motherboard and you only have to disconnect/reconnect at the PSU<->extension connection point.
However, that would add some extra cabling to route, which isn't a big problem for the P182, but if done incorrectly looks bad 😛 (and possibly obstruct airflow if you leave it dangling inside the case)
Of course you only need this if you're planning on swapping PSU's or reconnecting that plug often for some reason..
I've got a P180 v1.1 (same layout as the P182) and just used an extender for the 8pin Aux conector. It makes life much much easier & it also let me route my conector around the back of the case instead of over the video card and under my Tuniq.
It is 3 months old and I'm sell it because it would take too much modification to use for a water cooling setup. I was hoping to use it for water but just not a good water friendly case but a fantastic air cooled case without a doubt
-sponge
