Best way to remove cat urine odor from garage
Leros
21,867
7
I'm moving into a new house this weekend. The previous owners had cats that stunk up the garage with cat urine.
The previous residents just moved out a week ago and the realty company sprayed some sort of cleaner, but its only doing so much.
Any tips for getting the odor to go away. I assume its been soaked into the porous concrete.
ElFenix
102,404
8,575
replace all dry wall
replace all studs
replace all concrete
seal new concrete with epoxy paint
Drako
10,697
161
You can also seal the current floor, locking the odor in, but it will always be there.
Leros
21,867
7
replace all studs
The garage has new sheetrock. The walls were actually bare before... I wonder how much cat odor is stuck inside the walls now.... hmmm :hmm:
Leros
21,867
7
How much work/cost is that? I'm just renting this house, but I do plan to spend some significant time in the garage.
Drako
10,697
161
If you're just renting, then I would just live with it, unless it is truly overpowering.
FoBoT
63,084
15
fobot.com
burning?
Doppel
13,306
Eventually the smell WILL go away, it's not an endless magical source of energy. Until then there is a cat spray you can buy at a pet shop to assist in odour but I've no idea how well it works.
Leros
21,867
7
Well, I plan to live here for at least two years and I'm the kind of person who spends many hours a week in the garage doing various things.
Leros
21,867
7
I've used those bacteria pet removal sprays on carpet before. Ito worked really, but I remember it being expensive.
I would need a lot so that I can spray it all over the garage and spray enough so it soaks into the concrete.
dualsmp
1,627
45
I'd get a deck brush, a bucket, and use some detergent and scrub down the whole garage floor. Then hose it out and let dry.
Then to absorb and lingering odor put one box of baking soda in each of the four corners of the garage. About the best you can do.
sjwaste
8,757
12
White vinegar. I remember my dad used it to get the smell of cat urine out of a chair once, and it was far more absorbent than concrete. White vinegar and a scrub brush. Do it once a day for a week or so.
yhelothar
18,409
39
My car pissed in my carseat... it took forever and a lot of work for the smell to go away, but it did eventually go away.
I would recommend rinsing it and pouring vinegar over the offending area...
Then get some cat urine odor remover from a pet store.
This will remove about 80% of the smell. The rest, you'd just have to deal with for 2-3 months and it should start going away.
Modelworks
16,240
7
If you think the odor is in the concrete then you can use muriatic acid. Sold in the paint section of hardware stores. It is extremely strong so be careful with it and wear gloves and have plenty of ventilation and eye protection. Normally it is used to etch concrete because it removes a very thin layer on the surface priming it for painting, but it also removes things like oil or urine .
Leros
21,867
7
I went to Home Depot tonight to get some other stuff and I saw the gallon jugs of Odoban.
Each gallon jug makes 4 gallons of cleaner and costs about $10. That should be enough to really get the concrete soaked.
yhelothar
18,409
39
Cat Urine Smell Remover Recipe For Free
If the above doesn't work, you can always try muriatic acid or perhaps TSP (be careful with acid, because it can damage the concrete if left on too long.)
I've tried that one on my carseat. It didn't work nearly as well as getting the urine odor remover from the pet store.
It did still take out a lot of the smell though. It's a cheap alternative, but it's not a replacement in my experience.
mizzou
9,734
54
clean a gun in the room that smells like cat urine
now it smells like gun oil
