Originally posted by: rbloedow
pop them with a sterile needle.
Originally posted by: notfred
Take your shoes off and stop walking for a couple days. Then, when they heal, buy better shoes.
😕Originally posted by: Aimster
when your body is ready it will push it out...
Originally posted by: Eli
There's no way you can make them go away... you just have to let them heal.
If you pop them, you will be sorry.
Walking is unfortunately my only option as i don't have a car here and the closest store is roughly 1/2 mile down the road...
Originally posted by: DainBramaged
You could go to walgreens and get those patches made for blisters. They worked wonders when I was walking all over Europe.
They're going to heal the same speed anyway.Originally posted by: desk
letting them heal takes way too long. if you use a needle to let the fluid out, it will heal a lot faster. i used to run cross country and would encounter this problem a lot.
you could also by a product call 2nd Skin, which is sold at any pharmacy. it will help keep the blister from rubbing.
Push what out, exactly?Originally posted by: Aimster
what are you confused about my good man?
Just go to a local pharmacy or general store that has a pharmacy. They should have a whole section for feet.Originally posted by: aphex
Anyone know the UK equivalent of moleskin?
There is a boots downtown that should sell something i suppose...
