Best way to get a better raise.
Mayfriday0529
7,187
Usually the job I work for will get yearly reviews and raises in February but they are always late on it and it will probably be sometimes this month.
Anyways I got two and half years already with the company and I really need a good raise.
Last year I only got a about a 3.5% (3.5% x my hourly rate) raise which doesn?t compare at all to what most of my other co-workers make. Everyone that was here before I joined probably makes at least 30-50% more than me.
When my boss mentions the raise amount, usually he will tell me that it is the budget our department got and was approved by the CEO. I think they could afford more especially when several people that worked in my department left and now are paying three new people the salary of one person for all three.
How could I get more when my review is up? Should I just tell my boss that I contribute a lot and go out of my way for testing things etc? Should I mention how much I would like to get paid like a specific amount?
Any tips are welcome.
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
122
Drink some liquid courage and then go ask him....how does he feel about you showing up to work drunk?
Drakkon
8,401
usually once you've started at a place your kinda stuck at a 3-5% increase per year if your doing the same work year after year, and only if you take on more responsibility does it go up into the 10-20% range...thats just been my experience though.
Queasy
Moderator<br>Console Gaming
Aug 24, 2001
31,796
Ditto. I never hit a >10% raise until I got a promotion.
StageLeft
70,150
The best way to get a raise is to leave, and have the company consider you worth keeping. It worked for me a few years ago.
rh71
52,844
1,049
unfortunately true.
mwmorph
8,877
engage in a hostage situation. sorta likw the negotiator. :D
if movies has taught me anything, after you kill 20 sorrupt cops and yuo horrible boss, you get a huge raise, a hot gf/wife and then walk away happy.
FoBoT
63,084
15
fobot.com
you need to get the ball rolling BEFORE your annual review, they (the mangers) have already decided what you are getting at that point and it is too late. you need to talk to him 2-3 months before your review and then during all your reviews, make sure you are performing higher than average/exceeds standards
Toasthead
6,621
Ive been at my job for 2 years and my take home pay is actually 2 dollars LESS a month than when I started!
chrisms
6,615
What worked for me is taking up a new task and then working my ass off to do the best/quickest job at it. After a few weeks the boss knows you're "the best," and pays you more, but after you've got that title you can basically be lazy and everyone still thinks you're the best. This is better for manual labor jobs but may work in the corporate world as well.
Slvrtg277
1,004
Teh pron.
Seriously, like they said - consistently exceed expectations and hope for a promotion.
spacejamz
10,971
1,679
that wouldn't be bad a thing if you are putting more into your 401 or something...
but something else tells me that probably isn't the case...
Modeps
17,254
44
Honesty works pretty good. If not, go check out nettemps or monster and get your resume ready. The best way to increase your salary is to change jobs.
Demon-Xanth
20,551
At my work, the last three years have been: 0%, 2.5%, 2%. I've been at the max every time. Gas prices have bumped my commuting costs by $100/mo, and the cost of living for the area has gone up about 25%. I'm struggling to figure out if I can afford a house.
...so if you find out, let me know.
Mayfriday0529
7,187
There is not much more that one could exceed at my job. I work in Tech support and I make less than 30k a year. My responsibilities are Email and phone support and on the side i surf lots of forum websites looking for problems that customers have and will look for similarities and then bring them up with them and we look for solutions before going to the engineers.
I also test new software when it comes out look for bugs and even bring my work home sometimes. I have also represented my company in a few Microsoft road shows where my company was a partner and have also represented the company at a technology show in Germany.
Besides that there is not much more extra that i could do.
FoBoT
63,084
15
fobot.com
okay, then you need to get promoted. you need to find a new position they need filled and get hired for it
good luck
Mayfriday0529
7,187
good luck
There is Tech Support or Engineering which i do not quality for, there is no more up here.
FoBoT
63,084
15
fobot.com
then move to another company or get "qualified" , you should always be adding new skills to your tool box
DougK62
8,035
Sit down with your boss and be honest. You'd better have a good case with examples of why you deserve more money. Saying you want more because the others make more isn't gonna fly.
