best way to fix a hole in the wall.
JoPh
there is a hole in my wall, the wall is made out of drywall. the hole is about the size of a fist. maybe a little smaller.
what would be the best way of repairing it?
Buy a dry wall repair kit. Follow the directions.
Worked for me.
Twice!
Woah, that's CRAZY-talk! Think of the impliCATIONS, man! 😉
Stuff the hole with something, then splooge on it. Sand and paint!
errr.... by "splooge" I meant drywall spackle. Honest. 😀
But leave room for the LEDs!
Hmmm...that would be cool lighting along a baseboard!
hmm? Fist size? If its too big to mud up you can cut it square and then get a square piece of drywall to fit. Blow up a baloon big enough to put in the wall and hold the piece in place. Mud up, sand, paint.
The baloon will just fade away
What he said. Also, if there's a stud in the wall behind the drywall, you could nail or screw the replacement piece of drywall to that, then spackle, sand and repaint.
move
