best way to "extend" cat5e wire?
Cabletek
176
I have a hard time believing anyone but an electrical engineer could solder CATx wire and not create an impedance mismatch. Granted 15 Ohms is the tolerance level, but I seriously doubt anyone that posts here could do this in the situation described above with less than 10 Ohms in the mismatch. I'd be surprised if a single poster had the correct tool to even check the impedance in that situation and no it is not a VOM/DMM. You could check the impedance of single wires with a VOM/DMM, but not between two wires. You could even check loop resistance, but again that is not the correct diagnostic for what I am talking about.
That said, now we step out of the lab and into the real physical world, it probably works good enough.
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
You can't check any impedance directly with any DVM / VOM /DVOM ... they operate on a DC voltage to measure the resistance of the thing under test .... "impedance" implies a changing signal that interacts with capacitive and inductive components of the conductor, which typically changes with frequency.
Also, an impedance lump (i.e., immediate change of resistance/impedance), will screw a cable, even if it's within the "characteristic impedance" tolerance of the cable. The lump causes a reflection (standing wave) that destructively interferes with the primary signal.
imagoon
5,199
I personally use this:
http://myaccount.flukenetworks.com/...mo/DTX_ENGLISH/DTXDEMO_102006_2008_UPDATE.SWF
It most definitely will complain about an impedance mismatch. When it comes to soldering, I would expect it to pop up during the frequency sweep as a drop in the upper frequency response. I would expect a corresponding crosstalk increase as the frequency goes up.
Eug
24,165
1,809
This splicing thread brought back some memories.
During my reno an electrician cut one of my CAT5e lines by mistake. I got home to find the two ends carefully twisted together and taped up, and an apologetic electrician. Luckily the walls weren't up yet so I just replaced the entire line.
Also, a pipe fitter torched one of my other lines. They didn't tell me but I saw it. I replaced that too.
BTW, for my house when I couldn't replace the line, I've occasionally just crimped on plugs on the two ends and connected them with a $2 Monoprice CAT6 coupler.
http://www.monoprice.com/products/p...=10519&cs_id=1051903&p_id=7286&seq=1&format=2
Yeah, not a great solution, but hey, whatever. Worked fine for home Gigabit usage. I don't care if it doesn't pass master with you guys. ;)
ScottMac
Mar 19, 2001
5,471
That's a cleaner solution than soldering, because (assuming proper termination) the twist is maintained to the IDC, and the (Cat-rated) coupler should pass the signal as well as could be expected.
Scotch-Loks (Cat-rated variety) work well too, as long as the appropriate Cat-rated specs are observed.
Cabletek
176
As to VOM's:
Given a spool of twisted pair wire, I can take both ends of one wire, place the red lead on one end and the black lead on the other and measure the impedance of that one wire. What use is this? Given a impedance per length formula you can estimate how much cable length is left, that's about all it is good for, or if you get a weird number you can assume damage. The more realistic way to test is to short the pair at one end or use a UTP [100 Ohm] terminator, and test the LOOP resistance at the other end on the pair red on one, black on other [in coax one is the conductor/stinger the other is the shield and you use a 50/75 ohm terminator depending on your rating] [this also makes a good toner system, find more than 100 ohms and you found the terminated line], however, as I stated neither of these are what I am talkign about on the splices, so a VOM will not test the correct impedance as I was referring to the 100 Ohm Characteristic or surge impedance which requires special tools to actually test, and is based the materials involved and the distances between wires supplied. What you need is TDR which basically sends out a wave and look for reflections of that wave, determined the time it took to receive them and then using an attenuation and velocity of propagation formula estimates the distance to the impedance mismatch which is what causes the reflections.
Your tool does characteristic impedance or Time Domain Reflectometry and for that price it better, no? And I am surprised to find someone that does carry something like that around, but then it says it does FIBER too, so your doing rather higher up corporate runs I take it, small business IT is what I usually run into and I am lucky if they know they can tone UTP with a standard VOM, they always insist on going back to get the broadcaster half of the phone timer they left somewhere. Or running up to lowes/home depot to get another one...
I always wondered if you TDR'd a properly terminated cable, will it crash form doing indefinite calculations or not, heh. Look slike yours comes with ends. But I bet they have some osrt of response system in them too.
ScottMac
Mar 19, 2001
5,471
As to VOM's:
Shorting one end and measuring it with a VOM (or similar meter), you are only reading loop RESISTANCE, not impedance. Impedance will change with frequency, usually increasing with frequency.
You CAN do polarity and continuity, and if you're clever, you can check shield continuity of shielded / screened cable and the relative effectiveness of the grounding point.
If you TDR a properly terminated cable / pair, it sees in infinite length, as there is no reflection to time. you can still do return loss and some other measurement.
The 1800 is pretty versatile. I use it primarily for copper and use other stuff for OTDR, power, spectral dispersion and the rest. There's a special test set for PON / GPON.
13,837
All this gives me a neat idea. I want to see what is the "breaking point" of ethernet, and going to try all sorts of crazy stuff to a cable until I notice transfer speed differences. All these fancy meters may show things, but at the end of the day, it's all about what is noticable in a real world situation, or when it's being pushed to the limit in a real world situation (high speed transfer). I think this could be fun.
ScottMac
Mar 19, 2001
5,471
It would be interesting. Try to find a stable TX/RX pair of hosts or test suite.
If you decide to expand it, try a vendor-homogeneous (all components from the same class and product line of one vendor), the "cheap mix" i.e., the cheapest batch of mixed components, etc ...
We did this a long time ago (~Cat5) ... just after we did the SOHO switch versus commercial-grade switch testing.
imagoon
5,199
It would be interesting and depend of your needs. VoIP is rather intolerant of loss. 2% is generally noticeable in conversations. Surfing the web may not matter. Something like netflix buffers so it may not show.
wirednuts
7,121
4
with cat5, you really cant hurt speeds. tie it in tight knots even, you will still get full bandwidth.
i know this because we tried it in class.
above 1Gb speeds though, its a whole different story, and even when you use cat6 cable you need to have all the kinks out to get best performance. reason being that cat6 really isnt that much different then 5. you get more twists, and some crosstalk buffering if you get the augmented stuff... but for the most part, there isnt much to cat6 compared to cat5. utp cable just doesnt carry frequencies above 100mhz (1Gb speed) easily...
Eug
24,165
1,809
I ran Gigabit Ethernet over a home made CAT3 patch cable and it worked fine. However, it was only a couple of meters long.
I couldn't get Gigabit Ethernet to work over a cheap flat retractable patch cable though. My home network hardware down-spec'd itself to 100 Mbps Ethernet... but that worked fine. However, that cable was CAT-nothing, because basically it was a flat ribbon with all the wires running parallel to each other, about 1 or 1.5 m long when fully extended. It looked like this:
BTW, IIRC Mellanox supports (or has supported) 10GigE over CAT5e, over shorter than usual spec distances that CAT6a would support though.
I'm hopeful that when home 10GigE lands, that means it will work well enough for home use on my installed CAT5e and CAT6 (not 6a). I think the longest cable length in my house is probably about 75 feet or so. Note though my CAT5e is mostly good quality Belden, but the CAT6 isn't. If anything I wouldn't be surprised if my CAT5e is better than my "CAT6". BTW, some of it is labelled as "CAT6e". It's splined Ethernet cable that they claim exceeds the CAT6 (not 6a) spec, but I'm not sure I believe it. It all works great for Gigabit though.
skyking
22,790
5,950
What in the world would you need 10 for at home? "I can move an ISO at the blink of an eye". :D
Eug
24,165
1,809
Actually, that's about right. It's rather annoying waiting for say a 15 GB file transfer from my desktop to my laptop.
However, Gigabit is OK. 100 Mbps Ethernet was quite painful though. 10 years ago people were asking "What in the world wold you need 1000 for at home?" :p
