Best way to dry car after wash...
Doppel
13,306
I've tried and seen vids on drying cars after washing but none seem to really satisfy me in a "wow that's awesome" kind of way. I've read great reviews of the mr clean car dry system but it's apparently being discontinued (I think).
Is there anything else? I find that when i wash my car much of the water beads/dries before I can really get to it and who knows what's in my water now but the stuff leaves absolutely unbelievable water marks on my dark paint!
I've read that a microfiber towel is really the best you're going to get, though :(
thescreensavers
9,916
You need to keep rinsing the rest of the car while your washing, you do not want water to dry. Keep it wet.
Are you washing in the SUN? Big No no, always wash in the shade.
I use a leaf blower to get most of the water out and then use my drying towel to dry.
No water spots nada.
jteef
1,355
take the nozzle off of your hose and turn it down to ~1/8 to 1/4 open; just enough to get a smooth, slow flow. start with the roof and use the hose to sheet off the major water beads/pools. Then use a waffle weave microfiber to soak up the remaining. don't wipe, just blot up the water. next do hood and trunk, then the side panels and wheels last.
KentState
8,397
393
I've bought a lot from http://www.autogeek.net and recommend these:
http://www.autogeek.net/waffle-weave-drying-towel.html
http://www.autogeek.net/microfiber-waffle-weave.html
The first one is huge and can get most of the water off the car quickly. I then use the second set to clean any water that is left and do the trunk, hood and door sills.
Another option is something like this: http://www.amazon.com/Metro-Vacuum-B3-CD-Blaster-Motorcycle/dp/B0000CCXWA
Those blow a pretty good stream a warm filtered air and do a great job.
Throckmorton
16,829
A leaf blower? That will probably just blow dust on the car, and then you'll scratch the paint with the towel.
I used to have a California Water Blade and then a chamois. That worked pretty well.
Now I just use a microfiber towel.
KentState
8,397
393
If you are washing your car in a dusty area, the dust will get trapped in the water droplets regardless. If you are doing it right, you will have enough wax on the car to prevent micro scratches in the paint anyways.
Mike Gayner
6,175
You think a leaf blower is going to scratch your car? What you think it has a hopper of sand that it sprays out with the air? You realise it's just air, right? I hope you don't spend too much time driving at highway speeds - would hate for the coarse air to scratch your paint.
Shit some people say retarded things.
Throckmorton
16,829
I don't dry my car after driving it. I dry it right after washing when it has the least amount of dust on it... If I have to use a car wash, I dry it there or leave it alone and let it air dry. What don't you fucking understand about BLOWING air onto a wet vehicle causing more dirt to accumulate than just sitting in still air, and then the act of DRYING THE CAR WITH A TOWEL causing the dirt to scratch the paint?
Wait, why do you even wash your car? It's not like someone is going around dumping hoppers of sand on vehicles, so they must always be clean!
Better take your air filter out, since the atmosphere is so clean, dumbass.
Doppel
13,306
I've heard of others using leaf blowers but think the neighbors may finally call the mental police on me. I will try the waffle weaves :)
Not sure why I wasn't doing it all these years but redid it this morning and the final rinse was just the hose without attachment to let the water sheet off and yeah it really does work :oops: Made a ton less water to get rid of. Instead of wiping I blotted the excess with a microfiber. Starting to drizzle now but looks tons better than it did last night.
Imported
14,679
23
I use waffle weave microfibers too.. also try and sheet the water down so there's less to dry. :)
Edit: oops, read your last post.
Zap
22,377
7
Way BITD when I was young and stupid (arguably still am) I would wash my Mustang GT, and then "air dry" it by driving really fast. I think someone called the cops on me. :$ I was done and in my house, and a city police cruised by twice, looking at my car parked in the driveway.
sleep
582
rarely after i wash my car, would would drive straight towards the freeway.
i would never care how my car looked as long as it got me to point a to b.
thescreensavers
9,916
Yes its a possibility, but with Wax the 99% of the water gets pushed off, and I use some UQW, or QD as extra lubracant if I need to use my towel on the paint.
Using a Leaf blower, is less invasive then having a towel touching paint IMO.
Dr. Detroit
8,572
962
California Jelly Water Blade - gets the majority of it off.
100% cotton terry cloth towel to do the rest. I don't drive a BMW so I'm not anal about "microscratches"
Capt Caveman
34,543
651
California Water Blade, synthetic chamois then use Meguiar's Ultimate Quick Detailer and wipe dry with microfiber towel. Comes out looking great afterwards.
shortylickens
80,287
17,082
One of those big squeegee thingies to get the bulk of the water off, then a chamois for the rest.
lavaheadache
6,893
14
For an effective drying technique try this:
-travel in excess of 100mph for 3-5 minutes straight, pull over and check for streaks and wipe as needed.
-The same can be said for purging a bowel full of taco bell
lavaheadache
6,893
14
waterblades can scratch your paint, however they work very good when used properly
Howard
47,982
11
I use a leaf blower occasionally (when I don't have enough waffle towels). There is no god damn way it scratches the paint. Christ.
Now, the water blade - that's an accident waiting to happen.
