Deeko
Originally posted by: Skoorb
I've generally lowered the weight because I lose strength after each set, but I think the best is to incorporate both, and over recent months - mirroring what I see most people doing - I've started to raise the weight, and keep the reps steady. To do this requires, obviously, not going to failure on the first sets except for the last set of an excercise.
After a decent amount of weightlifting, you will learn to set the weight so that every set IS a failure set. For example....on bench press, I do 3 sets, 10x8x6...if I can fully do 10x8x6, that's when I raise the weight. Typically I can do 10x7x4 or 9x6x4 or something. You always gotta push yourself to the limit if you want to build.
