Best way to destroy a buttload of floppys
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Just transferred about 300-400 floppys to a CD today... Sensitive client data on all of them....
Best way to dispose of them all?
aphex
Moderator
Jul 19, 2001
38,572
Thanks, but we need someway to do this cheap :)
Wentelteefje
1,380
Monster Jam? "Car" versus "big load a floppiiieeeesss"
Magnetizing could destroy the data on it... Or do you have to get rid of the floppies as a whole?
EDIT: Microwave... :)
networkman
10,436
Got a paper cutter? One slice - the disk is history.
Failing that, if you want something more secure, you could probably use a heavy-duty office shredder that handles CDs, though I'd recommend removing the metal plate first. ;)
rbV5
12,632
Copy an important file to the floppy, this particular method has apparently destroyed several floppies in my day.
DaveSimmons
40,730
670
I hope you made _2_ CDs and had the burning program do verification.
You could use a power drill or dremel on stacks of floppies. Drill 1-2 holes in each, toss in trash.
Matthias99
8,808
I have to agree. :(
Burning them might be easiest (although, as noted, probably very environmentally unfriendly).
Putting them through an industrial-strength shredder (after removing the sliding metal cover) would also work.
Wentelteefje
1,380
Although it's not meant to be funny... LOL anyway... :p
Jeff7
41,596
20
Mail them to certain companies affiliated with the government. A few of them are REALLY good at losing things. :)
Fire - very secure. Not exactly environmentally friendly as was mentioned previously, but then, landfills aren't exactly good game preserves either. Chipper/shredder...well, if you had access to one, that'd do the trick real fine too.
suszterpatt
927
Boil 'em, mash 'em, stick 'em in a stew...
But in all seriousness, I'm sure that you can quickly dispose of them with a buzz saw. Environmental friendly too.
