best way to clean drywall sand dust off of painted walls/ceilings?
purbeast0
53,713
6,583
i've finished patching up some holes that i had to cut from the wall of a finished room, with painted walls/ceiling. there are about 10 holes total.
now there is drywall dust on the walls around the patched holes from me sanding it down after putting the mudding filler in the gaps.
it is also all over the carpet in a lot of spaces, but i ran my vacuum over some areas to test it out and it got the stuff up just fine, so getting it off the floor won't be a problem.
i am wondering though what the best way to get it off the painted walls, without messing up the paint on the walls and leaving any marks on them. anyone have any experience with this and wanna suggest the best way to do this?
this is the first time i've ever done anything like this so i'm a noob to it.
purbeast0
53,713
6,583
damp microfibre cloth.
i do have a few of those that i use to dry my car with. by damp you mean just get it wet then totally ring it out? so that shouldn't leave any streaks or anything on the wall then?
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
You must have an upright vacuum, not one with a hose? I'd use a longer hose on the vacuum & a soft bristle vacuum head. With a vacuum, you have to pay close attention to the air it's blowing out. Sometimes, that very fine dust makes its way through if you don't have good filters.
bignateyk
11,288
7
Damp sponge (the big ones that you use for grouting)... rinse and repeat. Unless it's a textured ceiling...
purbeast0
53,713
6,583
its a dyson dc24 animal vacuum. i didn't notice it spitting any dust out as it vacuumed up the dust. i only did one area that had the dusting from 2 patches that were close by in the ceiling. like a 4x4 area. it seemed to do a really good job.
Blackjack200
15,995
1,688
This.
I don't even think it should matter if its a textured ceiling as long as its painted. Spackle is water soluble, dried paint is not. Should wipe right off.
BTW, I'm assuming you sanded the spackle and not the drywall.
bignateyk
11,288
7
This.
Those textured/popcorn ceilings will tear a sponge apart like a cheese grater.
purbeast0
53,713
6,583
This.
yea sanded the spackle to smooth it out.
and no the ceilings are not textured they are smooth.
think i will go to HD at lunch and get one of those sponges for grouting and use that if that is the best way to do this, thanks.
gonna snag one of these
http://www.homedepot.com/webapp/wcs...&productId=100173109&R=100173109#.UPgqW6MZLJg
and one of those big orange buckets
http://www.homedepot.com/webapp/wcs...&productId=100087613&R=100087613#.UPgqeaMZLJg
twinrider1
4,096
64
If you foresee additional drywall/painting work in your future, I'd pick up one of these.
If not, I'd go with the vacuum/damp cloth method.
purbeast0
53,713
6,583
nah i don't see any of this in the future. it was to do some in-wall wiring on a finished area. now that it's done, hopefully i never have to go back in there!
purbeast0
53,713
6,583
one more quick question...
i'm assuming i should wipe over the actual area i'm going to be painting as well correct? again noob here who's never done this, so while this may be obvious to everyone, i just want to verify before i start applying the paint.
SheHateMe
7,251
20
Maybe I'm lazy...but I just use a new paintbrush to brush the dust off the wall before I paint.
purbeast0
53,713
6,583
you aren't going to get the dust off the wall doing that. this isn't just every day dust, this is joint compound dust from sanding. if you brush it, it will get some of it off but smush the rest into the wall leaving a white haze on it.
Imp
18,828
184
It's your money, but I wouldn't risk such an expensive vacuum cleaner on large amounts of dust as fine as drywall dust.
purbeast0
53,713
6,583
not sure what you mean. what is bad about vacuuming it up? and btw this is on carpet, not hardwood flooring.
Imp
18,828
184
None at all, just that when we vacuumed drywall dust using our old vacuums, they died. However, they used filters so maybe it's different. A Dyson is a pretty hefty investment, so I'd baby it a bit.
With our vacuums, the dust ended up clogging the filters and probably other parts. This stressed and killed the motor. We tried cleaning it, but drywall dust is very very fine to the point that it'll get through tiny cracks in large amounts.
A shop vac might be able to handle it, and those are relatively cheap.
purbeast0
53,713
6,583
ah i gotcha. yea i mean it seems to be sucking it up just fine for the areas i tried it. it also isn't like A TON of dust in the sense that it will have to empty the canister like 3-4 times or anything.
i just went and got a sponge and the tack cloth at hd so i'll give it a go tonight, thanks.
Sho'Nuff
6,211
121
so would you use that JUST for the area you are painting? or also the rest of the wall to get the stuff off?
Anywhere, really. I just painted my office and used tack cloth to remove all the dust that was on the wall from sanding drywall spackle. One cloth goes a fairly long way, and they are cheap.
sdifox
100,979
18,117
yeah. vacuuming helps too, but I guess the hose might get a little heavy :cool:
