Best way to clean an LCD?
Beev
7,775
I just got done using some windex and there are tons of streaks. Streaks that I wouldn't have gotten on glass which leads me to believe that there is a special alternative for LCD screens. What is it?
nakedfrog
63,626
20,074
A solution of 1 part rubbing alcohol to 3 parts water, I think. Something like that.
SSSnail
17,458
83
86
Depends on the USER's MANUAL, some LCDs have special coatings that would need special cares. RTFM!
Hav0k99
2,968
micro cloth is dust only
otherwise google for a solution to use to clean
Mo0o
24,227
Uh... windex is for glass only, it destroys the surface of LCDs. That being said, all i use is a sock and water which seems ok so far
d3n
1,597
Try and use distilled water, a 50/50 solution of that and Isopropyl alcohol. Most of the store solutions are 30% distilled watter anyhow so take that into account. Anything over 50/50 will tend to streak still.
KrillBee
1,433
okay, paper towels are bad, right? so its good to use cotton or some kind of cloth i assume.
now if you use water, you might have to press harder to get spots off. and when you press on an lcd it gets all colorful. that isnt good is it.
Kelemvor
16,928
8
If water doesn't work, you can buy stuff at OfficeMax type places that's for cleaning laptop screens. Don't know what's in it but it's formulated to not take off the coating and such.
But Windex is very bad for LCDs.
QED
3,428
What kind of spots do you have on your LCD that require more than a slight rub to get rid of???
:shocked:
KrillBee
1,433
:shocked:
finger prints that are probably 2 years old?
actually my lcd isnt that bad compared to some. Some LCDs look like the a window on a kindergarten bus.
when i worked at a college, i was sort of put in charge of loaner laptop maintenance. thankfully i only dealt with hardware though, another guy did the cleaning :) but sadly he used windex for a like a month, before someone snapped some sense into him, lol. Then he used paper towels and water.
geez, paper towels cant be good for them either.
Dritnul
781
almost ever big chain store wally-world target etc. sell some sort of LCD cleaner whether you trust it to work or not is up to you but i think whoever said RTFM is QFT
