Best virtual PC software
lowrider69
422
What did you use to get OSX up and running under VMware? I've got a Snow Leopard disc I bought to use to build a hackintosh sitting in my file cabinet, but haven't had time to really get started on it.
I would like to know as well. I read a few tutorials and all of them seem to have 15 steps involved and/or you have to download preconfigured files or hacks which i'm not doing.
sep
2,553
Using VirtualBox 3.x with NoGUI Startup (batch file) on my Windows Server. This allows remote access from any PC on my network. So far works great for what I'm using it for. Yes, this was my only experience with Vitural Machines so I'm ignorat to other solutions.
Looks like from this post there is VMware Player, Workstation & Server and I'm not sure what the differences are. I don't want to step on OP's toes so I'll start another thread about VMware once I've done some research.
Thanks Steltek, I didn't know about the VB-USB and was wondering that.
yinan
1,801
VMware player, essentially just starts up and runs preconfigured virtual machines. No changes to the VMs config can really be done. Free
Workstation kick ass type 2 hypervisor that runs on tops of an operating system. Allows for creation/cloning of virtual machines. Has a cost.
Server: Free, meant to be used on server OS for running VMs that need to be up all the type. It is really crappy, but it is free.
Steltek
3,493
1,250
The current version of VMware player can create virtual machines. It doesn't have all of the tools that Workstation does, but it includes the same creation and settings wizards.
Engineer
701
Can VMPlayer create images of other PC's (example: my work XP laptop) that I can then bring home and run (in case I need to access files from the laptop and I don't physically have the laptop at home)?
