best value in color calibrators?
dg27
144
I've calibrated two of my screens to the sRGB color space (Dell 2007FP and HP 2475w) and honestly I'm kind of disappointed: especially on the HP 2475w the colors still seem too vibrant and unreal. I wonder if I did something wrong in the calibration process because while the software offers a "before" and "after" view, there is almost no discernible difference.
dg
elconejito
607
www.harvsworld.com
Not sure about the eyeone you got, but on my spyder there are two things to calibrate to. One is the brightness which I fiddled with the brightness/contrast (a lot) to get it around 100 (which is supposed to be comfortable reading level). Then you balance the RGB sliders until the other number (which I forget what it's called) is as low as possible. 0.0 is perfect, i think 0.2 is really good, 0.5+ is bad. Mine started at .4 and had a noticeable color cast. After calibration it was down to 0.23. The before and after was quite noticeable.
So either your monitor is pretty good right out of the box, or maybe you havent gotten the target numbers to where they should be.
I read up on some reviews before i bought my monitors, and some monitors calibrate real well. Others dont. Acer 2216, which I was considering for a while due to price, were really good out of the box, but calibrating didn't improve them any further. The Asus vw222u that i got was "ok" out of the box but calibrated better than the samsung 2253bw (not available anymore) and it was a lot cheaper which is why i got them. I wonder if your monitor falls into that category?
dg27
144
All the reviews I've read of the HP 2475w say that out of the box it's unrealistic: reds are all candy apple, greens (like the XP start button) are bright emerald, but when calibrated it's outstanding.
I'm thinking I should fiddle with the monitor settings more before I calibrate.
To be continued...
Thanks.
dg
