Attic Diamond Member Jan 9, 2010 4,282 2 76 Jun 3, 2014 #27 BrightCandle said: You are missing the key option - 120+ fps. Click to expand... Apologies for the fault in the poll. Those responsible have been sacked.
E Erenhardt Diamond Member Dec 1, 2012 3,251 105 101 Jun 3, 2014 #28 All the listed options are "best waste of gpu power" The "best use" would be: GPGPU developing or "crypto mining" option.
Subyman Moderator <br> VC&G Forum Mar 18, 2005 7,876 32 86 Jun 3, 2014 #29 Number one thing is keeping your FPS at 60fps or above if you use a higher hz monitor. Everything else comes later.
DeathReborn Platinum Member Oct 11, 2005 2,786 789 136 Jun 3, 2014 #30 Have we hit 1,000 FPS in Quake 3 yet? 60+FPS & max details is the goal.
Ken g6 Programming Moderator, Elite Member Moderator Dec 11, 1999 16,806 4,788 75 Jun 3, 2014 #31 Best use? Folding@Home.
F Flapdrol1337 Golden Member May 21, 2014 1,677 93 91 Jun 3, 2014 #32 Why isn't downsampling in the poll? it's the best way to get rid of lots of gpu power.
Midwayman Diamond Member Jan 28, 2000 5,723 325 126 Jun 3, 2014 #33 Best use is to make refresh rate = frame rate (capped with no variance) for your low persistence monitor.
