- Sep 24, 2001
- 2,613
- 4
- 81
My 14 year old is starting to get the dreaded zits. What is the most effective stuff to use?
Thanks
Thanks
Originally posted by: EGGO
They banned Accutane I thought. I was one of the first people on it back when they didn't release all of the side effects.
Originally posted by: moshquerade
another vote for accutane, but of course the dermatologist will want to try topical ointments and maybe oral antibiotics first.
i personally never took accutane, but i know someone who did and it worked wonders.
the problem with accutane is someone committed suicide while on it so they are trying to pin that on the medicine. also, it causes birth defects so they are very strict with females who go on it.
Originally posted by: Cyraxx
+1 for Accutane
Nothing worked except Accutane. Dry side affects? Yea, but worth it. Mine wasn't too severe, lots of polysporin for nose dryness and lots of stuff for lips too.
I'd be wary of using accutane. Anything that causes permanant skin dryness and other permanant changes to the skin can't be good for you. There really are no long term studies on its use, so personally, I would hold off on it.
+1 for Accutane
Accutane worked for me too. I was on everything (retin-a, clindimyacin, benzoyl peroxide, salycilic acid, antibiotics, mostly at the same time) and the only thing that really did it for me was accutane. Taking it sucked monkey balls, because I couldn't go in the sun and I had to use chapstick all the time. Also, it made my cuticles bleed from dryness and I had to get prescription medicine for that as well, but after I was done with 2 cycles of it I rarely had acne, and I only had to use a special soap to keep it at bay. Now I've somewhat outgrown it (I'm 24) but I get the random zit here and there, usually due to sweating, but nothing like I used to. Accutane is definitely an extreme measure, though, you really want to exhaust your options before considering it.
Originally posted by: minendo
My dermatologist had me try several different options before finally putting me on Accutane. It sucked taking it, but it did the trick.
