Prolimatech PK-1.
^ the best unless u want to go single application style like Indigo Extreme..
This was done by 2 friends of mine. Vapor, and Skinnee:
http://skinneelabs.com/2011-tim-results/3/
Prolimatech PK-1.
Someone please explain the hate towards AS5. Because I only see 1/5 of a degree Celsius difference between that and MX-2.
I find aigo's chart interesting as it differs somewhat from the massive study Benchmark Reviews did on TIMs in 2009. (link below)
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=150&Itemid=62
It's more because of the 200 hours it takes to set
Arctic Silver must be lying to its customers then when it says it is not conductive but capacitive in nature.And because it's electrical conductive and usually costs more per gram (compared to MX-2).
I like MX-2. It's cheap, very effective, and very easy to apply and clean. Hell, according to Aigo's chart it's the 7th most effective TIM out of ~30 tested. Not bad.
I subscribe to the notion that most TIMs are vastly similar and that surface preparation and correct mounting of a decent heatsink is more important.
I've never actually noticed any difference in temps, after supposed "burn in" of AS5.
I did mention the TX-2 and how competitive it was. I assume the TX-3 and TX-4 only improve on it, but I can't be sure as it is not available in my place. But if my favorite shop started carrying the TX-4, that would be what I'd be using now, seeing as to how positive my TX-2 experience was.I'm surprised nobody mentioned Tuniq TX4.
I meant similar performance, not composition, although that seems to be the case as well.From product MSDS, except for the exotics like Indigo Extreme and IC Diamond, most TIMS are formulated from aluminum, aluminum oxide, zinc oxide, carbon black, and either a silicone or polyester oil. Arctic Silver 5 contains silver (amount unknown), aluminum oxide, zinc oxide, and boron nitride in a polyester oil.
The higher viscosity TIMS probably have higher solids concentrations which may make them perform better but are harder to work with.
http://en.wikipedia.org/wiki/List_of_thermal_conductivities
Just going by the Skinneelabs tests, the greatest temperature variation between best and worst is only about 4C. If you're splitting hairs about such a minor difference, then you should be concentrating on the other factors that affect your cooling (heatsink, fans, OC/voltage settings, etc.) instead. Pick a TIM that spreads well and be done with it.
This and what the price/performance ratio is. Is it worth ~$10. an application for Indigo Extreme for a few degrees increase in performance.
You probably meant to say it was deprecated (as in phased-out and replaced by an improved product). Depreciated is an economic term relating to the decline in value of an item over time and use.To those still using AS5: Once it's used up, don't buy it again. It was depreciated long ago.
