Best Thermal Grease
jodhas
I've been out of the loop for a while. I'm still using my Artic Silver 3.
What is the best thermal grease for my AMD XP 2600 (Barton)?
I really like Shin-etsu (p.e. Coolermaster Premiun). But that, Artic silver 3/5/ceramique will perform pretty similar.
On my setup I haven't noticed any difference when I switched from Arctic Silver 3 to Arctic Silver 5. I'd use what you got left for AS3, before buying anything else.
I would use my Arctic Silver 3 but I left the cap out and it's been sitting inside the drawer for about 1 year. My XP2600 hovers around 105 degrees on my slk-800 with Panaflo.
I applied my AS3 about 2 weeks ago and it's giving me this result.
So, what is the best thermal grease out there right now?
Arctic Silver 5 or OCZ Ultra 5+ (rebadged AS5) is tops on my list.
Your AS3 should be fine and buying AS5 would yield little if any difference. I don't think Arctic Silver seperates over time, which is one of the main advantages of it (someone correct me if I'm wrong). Your temps are good... that's about 40C?
AS3 is still a great choice. Just make sure you're applying a paper thin layer, or else it actually hurts CPU temperatures.
And of course a vote for ceramique; apply as in nokiadude's instructions with same warning, nonconductive, after burnin time amazing (to me but I'm easily dazzled) temp drops
