- Sep 13, 2007
- 7,228
- 19
- 81
Wow, ABC is the only channel you can receive with the indoor antenna. You're not going to receive blue or violet code channels without a big outdoor unit. The Fox station is going to be a problem.
Lot of the antennas have color codes outside the box to tell you which channels you can pick up. I have the RCA ANT751 which is only color coded for Yellow, Green, and Red. I can't pickup Blue or Violet coded channels.
You're going to need something like Winegard HD7698P with something like this preamp. The Winegard antenna is rated blue. They don't make violet code antenna. For violet color, you're supposed to use blue antenna with preamp. You might try installing it without preamp to see if you can pickup the Fox channel. If you can't or the signal is weak, then add the preamp. No point in buying the preamp if it works without it.
Double check with TVfool to make sure the AntennaWeb info is accurate. The TV Fool site is more comprehensive and accurate. You have to make sure the antenna is pointed in the direction of the Fox. You can use the iPhone compass app for that.
I'm no antenna expert. All this is just what I read and learned while researching the antenna for my house. Mine is in the attic which supposedly cuts the effectiveness by 50%. But I'm less than 20 miles away from all the stations. I can pickup all the major channels like ABC, CBS, FOX, NBC, PBS, TBS, Univision, etc with regular indoor antenna. I added the attic antenna because my wife wanted to watch KBS and MBC which are two Korean channels the indoor antenna couldn't pick up.
You can also ask the sales people at Solid Signal for the type of antenna you would need.
TVtool is giving me drastically different result. Link Looks like an indoor antenna of some type would work to get the major channels according to this. I can do a roof mount but would highly prefer not too. Thoughts?
