Originally posted by: Marlin1975
Originally posted by: Ramma2
Get a peice of wood and a mallet and just hamemr that sucker out of there!
Well the crank is still in there but I have put a jack on the rod and pushed it up until it starts lifting the whole car.
uh, xyxlene will not eat metal.. lolOriginally posted by: TitanDiddly
Aerokroil FTW.
Try pouring some strong-ass solvent in there to destroy the sludge- and your piston rings in the process. Xylene should work, get it at paint stores.
Originally posted by: RayH
Originally posted by: 0
Originally posted by: GalvanizedYankee
WD-40 has it's place. It's misapplication is wide spread and I find it highly over rated.
It's VG for wiping tooling for storage. That's all I use it for.
Kroil is OK but stinky, penitrates the skin easily and does not work as well as Nuts Off.
Kroil probably works well on clean machined surfaces but not corrosion. *shrugs*
I have Kroil here but rarely use it. I have worked in the oil patch and diesel salt water marine
and nothing works as well as Nuts Off.
OP, you must get your own Nuts Off http://www.thomasregister.com/olc/50691005/phel9_6a.htm
It's made by Spray Products Corp., Norristown, Pa. 19404. Bar code: 51661 75516
Part# on my 11oz can: 075-516
I provide the above so you can find it locally.
24 hours after being applied, corrosion melts...Period!
I had a boss that restored vintage deep sea fishing reels in his quiet field office. One day
I heard him cursing stuck unobtainium screws. I gave him an employer provided can of
Nuts Off. The next day he drove out into the field to thank me with a cold Arizona ice tea.
The stuff works!
...Galvanized
Where does one get this stuff? I did a search and came up with nada.
Can be ordered direct from KanoLabs. I thought it smelled better than other stuff, not that I would use it indoors.
UPDATE
Well I got the 4th piston out. The center 2 and 3 are moving but will not come out and number 1 has not moved a inch.
I have been using PB blaster. Now that I have piston 4 out it seems to be sludge that is holding them in not rust. Had to soak piston 4 in pure purple stuff to get the oil rings off.
But 2 and 3 piston will come up high enough for me to remove the top piston ring but gets stuck at the top? I have now even used some engine degreaser trying to see if that would help and even jacked the piston up with my jack. No ridge in the engine that I can feel. I have sanded the wall to make sure. And number 1 piston I have no idea.
I'm talking about Nuts Off. Wasn't where you said it was.
Yikes, that's scary. Sounds like the engine is going to need a complete rebuild, that's just not normal.
Originally posted by: fbrdphreak
Congrats! I call dibs on first ride
