Carson Dyle
Right now I have just two computers in my home, one running WinXP and one Win2k3 Server. I'm installing a couple of new 2TB drives in the Win2k3 server, which isn't capable of correctly aligning the drives. XP is the same.
Both disks will be used only for data, so will have just one large partition each. Right now I'm using diskpar.exe on the XP computer to create the aligned partitions, but one question that I can't find a good answer to is the ideal offset to use on these drives.
The two drives are:
Samsung (Seagate) HD204UI
Western Digital WD20EARS
They appear to have exactly the same drive geometry (according to diskpar):
Cylinders = 243201
TracksPerCylinder = 255
SectorsPerTrack = 63
BytesPerSector = 512
DiskSize = 2000396321280 (Bytes) = 1907726 (MB)
WinXP and W2k3 both align the first sector at an offset of 63 sectors (as they do for all drives), which is unaligned. Googling, I've read suggestions of using 64, 1024, 2048, 4096 sectors. I've also found quite a few guides to aligning partitions on SSDs, but don't know how much of it is applicable to AF drives.
What is the optimal setting?
What does Windows 7 set as the standard offset when partitioning 2TB drives?
The two drives are:
Cylinders = 243201
