Best router for range?
My sister moved into apartment close to my moms and wants to share a connection. I ain't sure they will be able to do this since she is at least 100ft from my mom and there are at least 3-4 walls in between them. I seen a belkin at Wal-Mart than claims up to 700ft of range which I am sure is probably not accurate and if it is it's probably outdoors. They already have Dlink PCI wireless cards they are hoping to use.
Whats the best router for this if any? Or setup for this?
Today's woot got good reviews, even if it is a refurb listed. MIMO is what you are looking for in regards to getting the best ranges. I think Cnet, just did a review on a bunch of wireless routers, check them out and you will see
reveiw results are in...
I doubt that you would find a Magic Entry Level Router that would o 100? and 3 walls out of the Box.
Link to: Wireless What Should I Get?
The best Method to Extend Wireless Coverage depends heavily on the Specific Environment.
Look at these pages they describe most of the options that are within the means of Entry Level users, and choose the one that fits you environment best.
Link to: Extending the Distance of Entry Level Wireless Network.
Link to: Wirelessly Bridging Home / Network.
Link to: Hi Gain Antenna for Entry Level Wireless.
In general, the best Method involves using multiple units connected with wire to the source.
Or WDS ( Wireless Network - Configuration Modes. ) system using Hardware of one Brand across the board.
Wired connected Access Point is the best since WDS cute the "Speed" into half past the second unit.
:sun:
If you want to take advantage of the full capacity of the rangeMax you need the matching card.
For the long run take into consideration that the RangeMax might be the end of the line. I.e. when the final 802.11n would be out the RangeMax probably would not be upgradeable.
:sun:
what do you mean might be the end of the line and final 802.11n? Is the current rangemax just a beta 802.11n or something?
The RangeMax is decribed om NewEgg page as, NETGEAR WPN824 IEEE 802.11b/g RangeMax Wireless Router - Retail.
The RangeMax is defined on Netgear own Site as an 802.11g on Steroids.
Quote from http://www.netgear.com/Products/Routers...WirelessRoutersandGateways/WPN824.aspx
NETGEAR?s RangeMax Wireless Router extends your wireless network coverage up to 10 times that of standard 802.11g, thanks to an advanced Smart MIMO (Multi-In, Multi-Out) technology that incorporates seven ?intelligent ? internal antennas.
I.e. as far as they are concern it has nothing to do with 802.11n.
That does not mean that it does Not work well. It means that when the real 802.11n would come out you would be stuck with $200 (Router and Card) that is EOL.
Soo, if you are an Enthusiast that is going to be upset about it, stay away from it.
:sun:
heh well I myself might be. But this is for my sister and mom who know nothing about this type of stuff I just know some. They would be happy with 802.11g for a long time to come. They don't do any file sharing just internet which 802.11g is plenty fast enough for the speed they have and will have for some time to come.
Thx for all the info I think I will give that rangemax and shot and leave it up to them if they want to get the card aswell. But it's possible where my sisters G card might not get that good of a signal/speed by just getting the rangemax card could increase both?
