best range extender
moh2004
9
I've a netgear adsl modem+rounter+wireless access point
I want to use an extender so that I can use the internet while I'm in my bedroom
What is the best range extender in the market now, regardless of the price, I just care about the performance nothing else
Thanks
ktwebb
2,488
Well your limited to Netgear for repeating anyway since your parent AP is netgear. And there isn't a best anyway. If it works it works if it doesn't it doesn't. I guess you could ask what has the best antenna and radio senstivity. Any netgear AP that has repeating functionality you'll be fine, albeit at greatly reduced bandwidth, which may not matter to you if all your concerned about is internet traffic
Night201
3,697
If you can get rid of the netgear access point, Linksys has an Extender which you can use. I've set one up and it works pretty well. You'll lose 50% of your bandwidth, but for basic internet and stuff, it shouldn't be too bad.
bersl2
1,617
Retransmitters shouldn't be dependent on manufacturer. All that needs to be done is to listen for and rebroadcast signals on a certain number of frequencies.
Need4Speed
5,383
just make yourself a new antenna or buy a better one...often that will give you more than enough extra range.
standing waveguide antenna will probably be overkill....so google for pringle can antenna or cantenna
DaRock42
88
ummmm...u lose bandwidth when you use the extender???
ktwebb
2,488
Yes. Pretty simple logic. You have one radio that has to transmit and send to the parent AP and the client machine.
JackMDS
29,547
423
As already stated by kwebb.
1. Repeaters (Aka Extenders) work only with the same chipset of the source.
2. Entry Level One Radio Repeater cut the ?Speed? into half.
3. Linksys Repeater (Extender) solution is not different then the other Brands.
Repeaters are the last resort solution when the combination of Cable and AP is not possible, or and the envioroment is not conducive for Antennae solution.
May be this can Help.
Link to: Extending the Distance of Entry Level Wireless Network.
Link to: Hi Gain Antenna for Entry Level Wireless.
:sun:
P.S. The are times in live that Wishful Thinking might Help. Solving Computer related problems is NOT one of them.
Rottie
4,795
I was going to buy extender but why lose 50% of bandwidth?
mdcrab
2,105
I have a preference towards Netgear, but am currently using a LinkSys WRT54G. The software interface that Netgear uses is considerably better. Anyway I like the transmission power setting available on the LinkSys to extend the range, but I am thinking about going back to the Netgear Router WGR614v4 and using a:
WGXB102
Has anyone here have any experience with these units? They are a little pricey, but since they are new maybe the price will come down.
mdcrab
ktwebb
2,488
Unfortunately that isn't the case. May work with other Mfg but probably won't. Non WDS repeating is not a standard. It's a bit more complex that just listening and repeating.
