RealWarlock
Ship it to me.
Originally posted by: Pariah
didn't realize that the entry level raid cards used up such a large portion of the cpu...
They don't. Not in a 2 drive RAID 0 array. RAID 0 requires basically zero calculations and doesn't tax the CPU. If all you want is a 2 drive RAID 0 setup any cheap software card will do just fine. It would be a complete waste of money to spend over $100 on a card for something like that.
Originally posted by: bgeh
apparently, the SATA RAID problem has been fixed with the 17 bios(Rev 1.0-1.2) and i forgot the bios number already for the Rev 2.0 and the 1.00.28 drivers but with a big hit on performance. the 1.00.29 should fix that
my friend is experiencing the SATA problem, but with only one drive
he has the exact same mobo as me because i bought them at the same time
Or you could setup software raid 0 with XP or 2k
you sure it's been fixed? i heard that there's supposed to be a driver update soon that fixes it...
anyway... we'll wait and see...
my windows got corrupted last night when we had a power surge so i'm glad i have this second hard drive to install windows on AGAIN... 🙂
but still... what do i do with a 60 gig maxtor ata 133 hard drive that's practically brand new???? 🙂
should i just use crappy raid 0? 🙂
Originally posted by: thehire
I am looking into getting IDE RAID 5, but I'm not liking the cards I'm finding much. Neither the 3ware nor the Promise cards allow you to non-destructively expand the array to another disk without destroying the existing data.
I want IDE RAID 5 because I have a huge amount of data that I'd like to have safeguarded without having to buy expensive backup hardware and media.
So, I guess I'm looking for advice - a good IDE RAID card that's capable of RAID 5, and has firmware that allows non-destructively expanding an array.
Anybody know if such a device exists?
Thanks!
Originally posted by: BentValve
So what are the raid possibilties for 2 drives? Also can someone tell me what sort of performance gain one could expect from a 2 drive raid set-up?
If all you want to do is store it, why not use DVD-Rs? They are permanent and store about 4.7GBs of info each. 🙂
If you have "THAT MUCH" data, buy a bunch of 200GB, 5400 rpm drives. Cheap. Load'em up. Put drives in anti-static bags, then seal inside watertight box, put that box into Safe Deposit box at bank. Last forever.
I'd need to buy about 80 DVD-Rs, plus a DVD writer.
I suppose I could copy the data to hard drives and store them away, but the data continues to grow and it would be mighty convenient to have redundancy where the data is being used.
It sounds like IDE RAID just isn't quite ready yet.
Anybody heard anything about the external arrays of IDE drives that connect to the computer via SCSI or Firewire or USB2? I've seen a few while doing some searching, but didn't see any prices or data about how they perform.
Two drives only? You can do RAID0 which stripes the data evenly across both drives...typically results in about 2x the performance of a single drive. If one drive fails, you lose everything. Not a big deal to someone like myself that owns (or has...😉) the CDs for all my proggys.
Or, you do RAID 1 which is mirroring. Data is duplicated across both drives simultaneously. If one drive fails, you lose nothing.
Thanks Mike, sounds like raid 0 would work well for me then since my PC is just a toy. What card(s) would you recommend? <$100 would be nice.
I'm taking a slightly educated guess here. The kind of card you'd need, $500, easy. The tower w/PS, another $500. Drives are about $250 each. Plus cables, terminator, other stuff...Big money...well, "big money" is entirely subjective, now isn't it?
Originally posted by: Joshaze
Why not just use the free, built-in RAID-0 (Win2K) or RAID-1 capabilities of the Operating System?
