Best Processor Under $500
aaksheytalwar
3,389
3930k will be a lot better than Oced 2700k or 3770k Oced, even at stock. Once Oced it goes further. The difference will be enough for you to measure without any instrument or watch or benchmark. Not in games but in heavy 3d apps which use 6 cores. Going from a 4ghz 920 to 5ghz 3930k will make performance increase by up to 100%. However even a 4ghz 3930k will be about 30-60% faster at least in most med multithreaded apps. In heavy mutlithreaded apps you will see from 50-80% performance increase
But you will need to spend $300-350 on a mobo and 16 or 32gb quad ch ram preferably 1866 or faster Cas 9, but minimum 1600 MHz Cas 9 with quad channel, preferably 32gb based on your usage.
Don't go for a 980x, it is half the upgrade of an Oced 3930k
bunnyfubbles
12,248
3930k is a lot better than 980x. Get either 3930k for a med-high upgrade or 3770k for a low-med upgrade.
the CPU really isn't that much better
the best part about SB-E vs. Westmere is X79 vs. X58. You get Intel SATA6, PCIe3.0, and up to 33% more memory capacity/bandwidth with quad vs. tri.
its really all up to the OP. It sounds like he could benefit from a 6 core CPU, and thus something like a used i7 980 would service him well, or even a new one if he can push his budget. But a full on 3930K upgrade is going to cost at least $800, most likely closer to $900+ if he gets new RAM as well.
and speaking of RAM I'm pretty sure single user scenarios really won't benefit much from more than DDR3-1600 with Sandy, especially SB-E with its quad channel. Recommending 1866 is kind of ridiculous IMO.
Granted, with how cheap the low profile Samsung Green stuff is, and how very easy it is to overclock, it would be pretty easy to go ahead and load up with that.
tweakboy
9,517
www.hammiestudios.com
If your doing Video Editing or any type of production grab a 16 threads xeon processor will use all 8 cores and 16 threads total.
If your gonna upgrade do it right. and put in 128GB of ram. ok 64GB lol
skulkingghost
1,660
@Tweakboy I like your style.
I have an SSD as my main disk now. It looks like a lot of good options. I will look into the processors listed above. I definitely want more ram, probably 24gb, but if I can save up a bit and do a nice XEON system that might be the way to go.
crazymonkeyzero
363
Joseph F
3,522
A Core i7 2600k would be faster than that Xeon.
Now, that Xeon would be awesome if you could OC it, but the BCLK is locked on them.
