Im going to mount 2-120mm Sunon fans with 108cfm each. One for intake, one for exhaust. What would be the best place to mount these? I was thinking about putting the exhaust parallel to the CPU so it could suck the hot air out. I want a fan to blow over my video card so I bent a PCI slot cover and drilled a hole in the end of it, then attached a 92mm fan to it and screwed it into a PCI slot so it extends over the video card. Would it be better for cooling to have the 92mm blowing on the card and the 120mm mounted on the case off to the right closer to the front? Or would it be better to just have the 120mm on the case blow directly on the video card? Thanks
